跳转到主内容
加入维修社区 - 创建账户
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
Battery and screen replacement
Is there a guide to replace the battery and screen at the same time? Or how do I combine both guides to make sure I don't miss any steps?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Hi Emy,
As @tomchai mentioned, you do have to take off the screen anyway to replace the battery so you're most of the way there. To do both, here's the plan.
  1. Follow the screen replacement guide all the way through.
    iPhone XR Screen Replacement - iFixit Repair Guide
  2. Pull up the battery replacement guide and jump ahead to step 20, the lower speaker replacement step.
    iPhone XR Battery Replacement - iFixit Repair Guide
The only difference between the screen replacement guide and the first 19 steps of the battery guide is that the screen guide has the additional instructions for removing the earpiece/front sensor assembly that you'll need to move to the replacement screen in order to keep your Face ID function.
Following those instructions should get you right where you want to be. If you run into problems, be sure to ask for help; after all, that's the whole point of this site!
Best of luck with your repair.
iPhone XR 显示屏总成图片
指南
iPhone XR 显示屏总成更换
难度:
中等
1 - 2 hours
iPhone XR 电池图片
指南
iPhone XR 电池更换
难度:
中等
1 - 2 hours
这个答案有帮助吗?
得分 3
1条评论:
Just a couple more thoughts for you on your repair.
In addition to the battery adhesives, be sure to buy the replacement adhesive for the screen ahead of time. I usually get a couple; they're not expensive and you'll have an extra on hand in case something goes wrong. I know I've messed up a couple of them on my first try. Be thorough in cleaning the old adhesive from the frame; the better a job you do, the more likely you'll get a good seal and return the phone to being mostly waterproof.
In pulling out the old battery adhesive, I've found it works best for me to roll it up on a pair of tweezers as you go. Pull it out as straight as possible; the higher you raise it the more likely it is to break before you get to the end. If it does break, there'll usually be a little bit left poking out that you can grab if you're quick; it will tend to retract back under the battery if you wait.
Let us know how it goes!
完成的
添加一条评论
You need to take the screen off to get to the battery anyway.
What you actually need to pay attention is how to fit the guides with the repair parts you got. Repair parts may be incomplete and may need some parts transplanted from your original phone to work properly, which may or may not be covered in the guides.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Emy Lamon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 369
