跳转到主内容
This guide will enable you to be able to repair any issue with your PowerBeats3 Wireless Earphones
38 个问题 查看全部
volume control button cover came off
Hello
With my earbuds the buttons of the volume control came off. I believe they still work just fine. The glue or adhesive just gave up. What can i use to glue them back down, and is there a preferred way of applying said adhesive?
Thanks!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi
From what you have said I would use the TESA tape that ifixit sells and cut it to the shape you need
If you can provide some photos I can better help you however this may not be necessary
Here’s a guide in how to add photos
https://www.ifixit.com/Guide/Adding+imag...
Also here’s a excellent video on how to repair the volume buttons on any beats in ears
https://m.youtube.com/watch?v=nXSjQzwTDM...
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 1
3条评论:
I have added a photo!
完成的
@stinder
Thanks for the photo
You could use tesa tape or b7000 glue like in the video
It shouldn’t really matter as ether one will do a good job
Just follow along with the video and your beats will be good as new!
If you need any more help just let me know
完成的
@stinder, when your volume keys cover came off, did the cable on the bottom also "tear?" I have a similar issue, but it may be more severe and gluing the cover back on will not solve my issue with the bottom cable assembly being torn.
完成的
添加一条评论
添加你的答案
Bryan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 36
总计 445
