跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
Can I replace the display and home button with another 6s plus?
Hey all So I have an iPhone 6s plus which is in good condition but it's only 16gb and I was wondering whether I could disassemble the display and use it on another 6s plus?...I'm planning on buying a used 64gb 6s plus with a broken display and home button so will I be able to change the two displays easily and is the repair beginner friendly?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Ahmad,
Your idea will work fine, as long as you transfer the old home button to the screen you're replacing. The home button is paired to the logic board for the Touch ID (fingerprint) function.
The part that concerns me about your post is your statement that the 64 GB phone you want to buy has "a broken display and home button". If you mean by that the home button is also broken and not usable, then you won't get Touch ID to work as only Apple can replace a home button. The good news is everything else will work fine if you transfer the entire screen from your old phone, including the home button.
Replacing the screen is one of the more basic repairs for an iPhone and is definitely a good place to start for the novice. There is a good repair guide for your phone available to do exactly what you want.
iPhone 6s Plus Screen Replacement - iFixit Repair Guide
Should the home button on the 64 GB phone be unusable and you don't mind losing Touch ID, then skip the last part from step 24 on about removing the home button and just transfer the entire screen assembly from your existing phone. If you can use the home button, then go ahead and follow the instructions to the end for both phones, moving the home button to the working screen.
Good luck, and if you need help along the way, just ask!
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Ahmad Mukthar 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 246
