跳转到主内容
Model M2453 or M6411 / 300, 366, or 466 MHz G3 processor
64 个问题 查看全部
doesn't seem to detect my airport extreme wireless card
I brought a airport extreme wireless card that stated the card would work perfectly with the iBook g3 model but that seems to be far from the truth so far do you have any ideals of what my next steps should be thank you in advance for your time
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
Hi odell, welcome to iFixit Answers.
The airport extreme wireless card will not work in your iBook G3 clamshell. You need to buy the first generation Apple wireless card. The airport extreme wireless card will only work in iBooks G4/PowerBooks G4 and G4 towers so return the card for a refund or maybe your seller has the first generation card if so ask for a swap..
Here's the card you need:
http://aftertheMac.com/wireless/airport_...
Here's probably the card you received:
http://orangeyemen.com/shop/images/orang...
这个答案有帮助吗?
得分 3
1条评论:
I missed that. Way to go. +vote
完成的
添加一条评论
Under the Apple icon in the upper left hand corner, Go to About this Mac. This is the system profiler. Hit the More info button. In the under "Network" go to the Airport Card. See if the computer can see the card.. Did you remember to plug in the connector to the card?
这个答案有帮助吗?
得分 0
添加一条评论
Lemerise is correct. Airport Extreme card won't work in clamshells.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
odell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,327
