跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Headphone jack doesn't work and volume buttons dont function?
Hi guys,
I bought an iPhone 3G (old but not bad) off craigslist the other day. The guy said that the volume button was "intermittent"
Turns out that the volume buttons "click" perfectly, but don't do anything. The loudspeaker and ear-speaker work pr erfectly but can't be controlled by the volume buttons. The vibrate button doesn't work either but vibrations work.
I have been planning to buy a Headphone Jack assembly, will that fix it? I have an agenda to fix the digitizer/lcd screen and the headphone assembly.
Does it take too much more effort to replace the rear plastic case if I've already opened the iPhone to the headphone jack assembly?
Thanks a lot!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
open the phone and check the connector from the headphone jack assembly - sometimes it's not properly seated.
but it could be damaged too
i would check the resistors near the connector on the logicboard - had a few phones with broken resistors! (would that check before you order a new assembly)
replacing the plastic case is easy if you already stripped almost everything - but as i mentioned earlier - try to get it fixed first and then order parts - they are too expensive - especially when the rest wont work....
这个答案有帮助吗?
得分 1
2条评论:
I have the tools necessary except a suction cup :(.
Can I just use duct tape?
Also, parts are only around 4$ shipped on amazon... But I'll check before I buy - Buy in haste, repent at leisure.
完成的
duct tape is not the best idea -removing that sticky stuff is no fun at all - you can also use a "household" suction cup (many different types are used in the kitchen or bathroom)
完成的
添加一条评论
添加你的答案
souleben 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,522
