跳转到主内容
这是一台发布于2012年的笔记本电脑,在日常使用环境中非常耐用。电脑配有13寸的屏幕,500G的硬盘,4GB的内存,Windows8.1系统可以在上面流畅的运行。
24 个问题 查看全部
About to replace the RAM SO-DIMM, what is the special film over it?
Hi, I am going to upgrade this laptop's SO-DIMM module. Following the great guide for it, I found my device has some kind of special "film" over the old module. It is about 0.5mm thick or less, gray colored and seems to be metallic (magnets attract it). It is very damaged though and breaks easily (see picture).
The user manual states: "For some models, a special film is attached onto the memory module to enhance the wireless LAN performance. When you replace the memory module, make sure that you do not remove the film". The picture in the user manual shows a different kind of film by the way...
Do you know if it is really important to keep it? Given its bad state it seems very difficult. I would like to buy a new one and put it just in case, but I don't know what it is called / how to shop for it. Can anyone give me advice for this? Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
This film is EMI/RFI protection. In this case it's preventing the RAM's noise from flooding the airspace with emissions which could interfere with either Bluetooth or WiFi radio signals.
Not sure why they used this method as most companies use a sprayed on ferris paint onto the plastic. The Iron particles held within the paint block some of the EMI but won't stop the RFI effectively. Here a copper foil would do better when it was also bonded to the metal chassis.
这个答案有帮助吗?
得分 1
3条评论:
Thanks a lot for the quick reply, and clear explanation! I have looked for copper foil but it always seems to have conductive adhesive... maybe I got it wrong or don't know how to look for it correctly (sorry, I'm new at this kind of things, and not English native), would that be dangerous for the RAM module? My old film seems non-conducting plastic on the other side, now that I look again...
Should I look for a copper foil but with some special adhesive, or an additional foil in between? I've also seen something like "20M/50M Conductive Fabric Cloth Adhesive Tape Roll Shield Repair EMI Multi-Width" (don't know if I it is OK to insert the seller links here), do you think that could be OK too?
完成的
I would apply electricians tape across any exposed circuits that you don't want to short out by the Conductive Fabric or Copper Foil tape, you'll want to bond the either to the metal case.
完成的
Thanks again! I will do so
完成的
添加一条评论
添加你的答案
Pachi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 536
