跳转到主内容
9 月 24 日发布的苹果 2021 旗舰智能手机配备 6.1 英寸 ProMotion OLED 显示屏、全新三镜头后置摄像头系统和 5G。iPhone 13 Pro 是 iPhone 12 Pro 的继任者。
57 个问题 查看全部
iPhone 13 pro removing MAGSAFE
Hello, im looking for an answer about iphone 13 pro, but i dont find it anywhere. Maybe you could help. My sister wants Iphone 13pro, but the problem is that my nepwhie had heart stimulator (pacemaker) and because of Magsafe it is not recommended to have it near it. Im thinking about buying iphone 13 pro and removing mag safe magnet and wireless charging pad from it, but the question is will it work without it? maybe anyone have tried it or somehow could check it?
Thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi
This is a really good question and I do have a answer for you
YES you can remove the MagSafe magnets but as you will know it will remove the magnetic feature of MagSafe
It shouldn’t remove any features at all but it will void your warranty
You will just have to dismantle the phone until you get the wireless charging coil out and with some heat and alcohol you should be able to pry the magnets out
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 1
2条评论:
Hello, thank you, but what about wireless charging coil? if i will remove it too? will Iphone start?
完成的
@Vytautas .J
As far as I know there is no reason why the wireless charging coil would cause a issue:-)
完成的
添加一条评论
添加你的答案
Vytautas .J 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 11
过去 30 天: 37
总计 679
