跳转到主内容
The Ryobi RS290G is a powerful Orbit Sander that boasts 12,500 rotations per minute. With an Ergonomic Grip to stabilize, and a dust bag to collect debris it is the perfect all-round sander.
Why is my Ryobi making a weird noise?
My Ryobi sander started making a strange noise and is not sanding proper. I made sure there were no loose screws, cleaned it and then let it sit for a few hours to cool down as I had been sanding on and off for several hours. Unfortunately none of these seemed to help. What could be causing this and is it fixable ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
What sander is it? Belt, orbital, detail sander?
完成的
It is a Ryobi corded orbital sander
完成的
添加一条评论
1个答案
已选择的解决方案
Possibly a bearing going, either to or bottom. I’d split it in two and remove the motor and check them. Could be wear on the base where the bearing sits.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
bhowse@live.ca 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 13
总计 803
