跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
260 个问题 查看全部
Replaced Logic board, worked for a couple months, battery now dead
I needed to replace my logic board as the original one had issues (https://developer.apple.com/forums/threa...) and was successful in doing so.
I used my MBP for a couple months post install and it worked great. Just recently, the battery life has been nonexistent and needs to be plugged in via USB-C or the laptop will shutdown.
coconutbattery reports:
  • Current Charge: 0 mAh
  • Full charge capacity: 208 mAh
  • Design capacity: 3.1%
  • Cycle count: 152
  • macOS Battery status: Poor
I double checked the contacts from the logic board to the battery controller and it looks ok to me. I can confirm that the battery isn't charging since I checked it with a multimeter and it showed around 2V.
My suspicion is that the problem is with the (new) logic board -- anyone else think so too?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Can you post the CoconutBattery screen so we can get the rest of the info. 在已经存在的问题里加入图片
I would stay given the age of your system you may just need a new battery.
完成的
Question edited with image. I don't think the battery itself is of issue since it retained charge normally before I replaced the logic board. Maybe the battery controller?
完成的
添加一条评论
1个答案
You've got a double whammy! First the battery needs to be replaced, while the cycles are not beyond the 1k limit, the age is over the expected lifespan. MacBook Pro 15" Retina (Late 2016-2017) Battery and here's the guide to put it in 2016年末带 Touch Bar 的15寸 MacBook Pro 电池更换
But you also have a charging logic issue! This system will need the logic board repaired as well. You'll note the charger is plugged in but the charger is not charging Charging with 0 Watts Which it should be!
MacBook Pro 15" Retina (Late 2016-2017) Battery图片
产品
$129.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
aluminum robot 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 70
