Hdmi signal lost but was running
Hello i have a problem with my pc, when i turn it on everything is good it open and work correctly and monitor too, after few min even if im not doing anythings hdmi signal turn off and the pc is freezed the reset button wont work either, if i shut it down at the switch where the power cable plug in and restart it it do de same or sometime monitor wont have signal at all. Cable are good and monitor is good all work on everything else, ive made update for everything with drivereasy and i play for a full night, next day same thing happen but now hdmi signal is lost soon as Windows open (sometime motherbord is very hot ).
18条评论
Ive putt a big fan to cool off the motherbord now the heat is good (almost cold at the touch) but its a random trooble i can play a whole weekend on it and sometime it lost signal after 2 min
由 Francis 完成的
@peavey What is the make and model of your monitor?
由 Dan A+ 完成的
@peavey
What is the make and model number of the PC or motherboard if a custom build?
What is the make and model number of the GPU card if it has one?
If it has a GPU card and if it has fans are they working?
If the CPU has integrated graphics, turn off the PC and unplug the GPU card and then try connecting the monitor to the motherboard's HDMI connector and check if it now works OK.
What have you tried?
由 jayeff 完成的
My monitor is a asus mg248q @Dan A +
由 Francis 完成的
@jayeff my setup is cpu amd fx-8350, gpu gtx 1650, motherboard gygabyte ga-990fxa-ud3, the gpu is 6 month old i had an amd readeon before and i was thinking thats was the problème so i change it but now the same problem come back, the fan on the gpu work well, the cpu dont have integrated graphics. The cpu is water cooled the gpu have a good fan and dont even get warm , ive putt a big fan to cool off the motherboard now its okay, ive update all window and driver.
由 Francis 完成的
显示更多的13条评论
