跳转到主内容
Apple 在 2019 年 3 月 更新了他们的 iPad Air 平板电脑,配备了 A12 仿生处理器和一块 10.5" 屏幕。
39 个问题 查看全部
Why can I sometimes not type correctly or touch the bottom of screen?
This started happening after I cracked the top left corner of the iPad.
Sometimes, but not always, when I type, it doesn’t work right.
Example:
I tried typing “example text”
I got “eaple. tet”
Whenever this happens, I can also not interact with the bottom inch and a half of the screen.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It sounds quite likely that you've damaged some of the circuitry that controls the touch screen function, i.e., the digitizer.
Unfortunately, on your model of iPad it's not possible for the average person to replace just the digitizer glass, as it is fused to the LCD display, so the only option is to replace the entire LCD / digitizer assembly.
There are several sources you can buy a replacement screen from, including right here on iFixit.
iPad Air 3 Screen - iFixit Store
If you're feeling adventurous, there's a DIY guide that will step you through the entire process of replacing the screen yourself.
iPad Air 3 Screen Replacement - iFixit Repair Guide
Good luck, and let us know how it goes!
iPad Air 3 Screen图片
产品
iPad Air 3 Screen
$199.99
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Ldangerous1 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 34
