跳转到主内容
发布于2018年9月21日,型号为A1921,A2101,A2102,A2104。支持GSM,CDMA / eSIM或 nano-SIM / 拥有64,256或512GB容量可选 / 有银色、金色、深空灰可选。(读作iPhone 10XS Max)
376 个问题 查看全部
How to remove the Passcode with out losing data?
I’m the owner of the device and the Apple ID being used on the device I just forgot the passcode from it and it’s also currently with the “iPhone disable connect to iTunes ”sign from trying every number I could remember lol 🤦🏻‍♂️
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
use 3utool and reflash with retaining user data
这个答案有帮助吗?
得分 1
3条评论:
The device is in disable mode would I have to get the device into dfu mode for the device to connect to 37tools and follow your suggestions?
完成的
@taco18 dfu or recovery mode
完成的
@tech_ni thanks for your help I tried following the steps to get the device in DFU mode, then flash process maintaining user's data I still find myself in need of a passcode even on the attempt to retrieve user's data and once I use a passcode I believe it's correct the phone gets into an iPhone unavailable try again in some minutes. If there's anything you know I should do to get rid of the passcode please help once again
完成的
添加一条评论
Put it into dfu. Recovery resets after 15 minutes turning the phone on losing the connection to pc, dfu doesn’t.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Taco 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 12
总计 124
