跳转到主内容
发售于2016年11月.PS4 Pro升级了硬件,使之能够支持4K游戏以及流媒体视频。
368 个问题 查看全部
Power Supply motherboard connector
Hi,
I was trying to clean my PS4 Pro and change the thermal paste while following some guides on the website.
When it came to the part of disconnecting my power supply, i use some plyers because the cable was stuck and i couldnt even wiggle it off.
Well, the full connector came of the board. Im attaching some pictures. Is there a way to fix this?
Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
yes it will require a soldering iron, solder, flux and a thin conductive wire
Update (07/18/2022)
the point with the blue circle is the pad you are missing so that red line will be the wire, you will have to scrape some of the green coating away from around the small hole at the end of the red line and thats where the wire should connect to
这个答案有帮助吗?
得分 2
1条评论:
Do you have any pointers on where i should connect the conductive wire?
完成的
添加一条评论
circled red now as you must of misread me saying the red line inside the blue circle
这个答案有帮助吗?
得分 2
添加一条评论
Just to see if i understood this one, (please refer to the image attached), i soulder points 1, 2 and 3 and solder a wire from point a to point b on that single red line so that it replaces the missing pad?
这个答案有帮助吗?
得分 0
添加一条评论
I did misread, apologies.
So it's like this, 1, 2 and 3 soulder to the connector and then red line (conductive wire) goes from that circle that i have to scrape to the last connector?
Sorry for my confusion but im kinda taken aback by all of this
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sérgio Oliveira 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 56
总计 573
