Where are studs in step 5 of" Ottlite PL-0094 Touch Switch Hack"
In Guide "Ottlite PL-0094 Touch Switch Hack" Ottlite PL-0094 Touch Switch Hack where are the studs in the the 5th step which states: --"the two plastic studs that hold the touch sensor circuit board in place"-- When I look behind top section of sensor board, --see picture above-- I only see one small white plastic square in the center --is that one? I do not see anything else that could be a stud. thank you
image|2700502]
18条评论
What guide are you referring to?
由 Andrew S 完成的
由 sue byrce 完成的
@sue_59 Can you remove the circuit board after taking out the needed screws?
由 Andrew S 完成的
are the screws first uploaded photo the ones I remove?
由 sue byrce 完成的
@andrewsawesome Thank you for taking the time to respond. I appreciate it. I removed the only two screws I could see on circuit board and this freed up one half of circuit board--see top photo. Unfortunately, I can't see any plastic or where it is affixed to plastic --except for a white square piece--shown in second photo.
由 sue byrce 完成的
显示更多的13条评论
