跳转到主内容
加入维修社区 - 创建账户
PlayStation 3 Slim是PS3的第二个迭代机型,机器型号CECH-2000。索尼电脑娱乐推出此机型来修复初代“胖机”PS3的诸多硬件问题,于2009年9月1日发布。
Fan not speeding up
Just removed IHS plates from both Cell and RSX, applied fresh grease. Before that fan used to max up after few minutes of any game, now it always idling. After 3 hours of MGS 4 it suddenly briefly maxed twice for 1-2 seconds both times with about 1-2 seconds pause, returned to idle speed and overheat warning appeared. Console turned off in few seconds after the warning. Doesn't seem to be false overheating, motherboard shield was pretty hot on touch.
I'm on latest official firmware (4.89). Fan test (when powering on while holding eject button) works, fan blows like crazy. Overheating message tells me that temp sensor also works. What could be the issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Solved it by installing evilnat 4.89 CFW and offloading temp management from SYSCON to CFW module. Looks like some issue with SYSCON like poor leg connection. Maybe I damaged it while removing IHS plate using heat gun or some other way. That may explain sudden fan bursts on high temp, it might be just high temperature temporarily restored that connection. Anyway, problem solved. Thanks for trying to help, bill!
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
A common mistake about thermal paste is using a lot. However, I don't know how this would cause your fan issue.
The fan works, the temp sensing works. The heat sink seems to work if it took 3 hours of play to heat it up.
The only variable is the replaced paste. Maybe redoing that insuring that it is a thin even layer on the device might work. Spread it with a razor blade evenly over entire surface
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dmitry 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 702
