跳转到主内容
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
559 个问题 查看全部
MacBook Pro 2013 not recognizing new battery shortly after install.
The Ifixit guide rated battery replacement for this laptop "very difficult" so I paid an experienced but unauthorized Mac repair guy to do the job. The battery seemed fine at first, but then the Mac didn't recognize it. Coconut verified this information. The repairman deflected the blame and said that it must be because of a bad motherboard. Suggestions? Might it be the battery connector?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Let’s get a better view of things, post a screen snapshot of CoconutBattery and post it here for us to see 在已经存在的问题里加入图片
Make sure the charger is plugged in. It could be a bad battery or the MagSafe connector is dirty or damaged. Then the MagSafe charger could be a knockoff which tend to damage the logic board comparator logic which is very repairable!
这个答案有帮助吗?
得分 0
2条评论:
I added the Coconut screen capture to my question. The laptop works fine with the power plugged in, but will not react at all when the Magsafe is disconnected. I suspect that the battery is holding a charge, but not discharging -- after many hours disconnected, when plugged back in there is no need to reboot as the login screen returns quickly.
完成的
@urbanshaman - Sadly you have a bad battery, contact the iFixit store to get a replacement.
完成的
添加一条评论
添加你的答案
Barry McVinney 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 29
