跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for riding, or ride-on, mowers, also known as lawn tractors, of all types used in tending large tracts of land.
Why won't my engine start when pto is connected?
Having problems with my simplicity mower... when pto is disconnected from the mower it will start up no problem.... but when pto is back on and connected the engine will not start... what could this be?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Hi,
What is the model number of the mower?
完成的
I'll have to look when I get off work.... not.sure right this sec.... but without knowing the model number have you heard of this problem before?
完成的
@Sara Baker
Not really but I know with some that there is a safety switch associated with the pto so maybe that's the problem
Knowing the model number may help to find the service manual which would have the wiring/parts diagram so that the reason may be found.
完成的
simplicity 1692287
完成的
添加一条评论
1个答案
最有帮助的答案
Hi,
Here's an image that shows how to test if the PTO interlock switch is OK.
If the switch is faulty the replacement part number is 1686620SM. Search online using the part number only to find suppliers that suit you best.
(click on image to enlarge)
If the switch tests OK here's a coupe of images of the wiring diagram - left side is the safety switch circuits and the right is the complete wiring for the mower.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Sara Baker 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 126
