跳转到主内容
发布于2012年10月23日。酷睿i5或酷睿i7处理器。配备Apple Fusion Drive.
Mac Mini A1347 Status Light Indicator
Hello All,
I have an interesting problem.
I bought a Mac Mini A1347 from Facebook Marketplace from an IT seller. He upgraded the RAM to 16GB along with a 1TB SSD, but in the midst of that, he said he must have bumped something because the front status light indicator does not function. The computer still works without issues, start up, and setup were like out of the box.
Is there a repair option for the status indicator light?
Thank you in advance,
TG
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The White LED on the front panel is part of the power supply assembly Mac mini A1347 (Mid 2011-Late 2014) Power Supply It could be burnt out. Here's the guide to replace it Mac mini Late 2012 Power Supply Replacement
The other possibility is the power supply to logic board connection got damaged in the process.
Replace a broken or damaged power supply in your desktop computer. This power supply is compatible with a Mid 2011 to Late 2014 Model A1347 Mac mini small desktop computer.图片
产品
$29.99
这个答案有帮助吗?
得分 1
3条评论:
THANK YOU SO MUCH FOR YOUR ANSWER! It means a lot and make sense.
Would replacing the power supply fix if the indicator is burnt out or the connection got damaged?
完成的
Thats the hope! Unless the logic board connect its self is damaged so when you replace the PS check it.
完成的
Thank you so much for your input, Dan. I will be ordering the power supply and then replacing it. You rock!
完成的
添加一条评论
添加你的答案
Tin 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 14
总计 433
