跳转到主内容
The Dell OptiPlex 7010 MT is an office-oriented desktop PC. It comes with a third-gen quad-core Intel i5 or i7 CPU. It has 4 DIMM slots, 10 USB ports, two hard drive bays, and two DVD drive bays.
short in circuit power
No power, no data the power supply is working fine
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
Hi are there any harms or burns on the board that you can see with a close inspection
完成的
Hi,
Please elaborate what you mean by no power?
Is there an amber or white light on the Power on button when you press it to start the PC and if either is on is it steady or blinking?
If the light is amber and it is blinking is there a pattern to the blinks i.e. count the number of blinks e.g. 2 blinks > short pause > 3 blinks > longer pause > then 2 blinks again etc
You said that "power supply is working fine", did you use the PSU diagnostic test on the back of the PC to check this?
完成的
添加一条评论
1个答案
最有帮助的答案
have you checked reseating removable parts? like ram hdd pcie slot graphic card , i have had a similar problem but with the hdd i have switched to a ssd and the problem was fixed for me.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Meo Roo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 325
