跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
Is it possible to separate the LCD?
Hello, I have 2 iPhone 4S's and one of them has a cracked glass but a good LCD and the other one has a non cracked glass but has a cracked LCD on the inside, when I was checking the tutorials I saw that I had to remove the glass panel with it which i dont want to. Help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
You can separate and reattach the glass with appropriate tools, which probably cost a truckload of functional iPhone 4s now.
这个答案有帮助吗?
得分 0
添加一条评论
Short answer: No. The display is laminated to the glass; they're effectively one piece. Separating them without further damage requires specialized equipment and/or a whole lotta luck, and even if you do manage to separate them re-laminating the pieces together (to make an actual functional piece) still requires specialized equipment and materials.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bwar Bahzad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 85
