跳转到主内容
PS4 控制器型号 CUH-ZCT1。这款由索尼电脑娱乐公司于 2013 年 11 月发布的六轴 3.7 V 锂离子电池控制器维修起来并不复杂。(注:拆解指南不适用于此型号)
Why does my r2 trigger keeps spamming itself
i have had this ps4 controller for around 2 yrs
and recently the r2 trigger keeps spamming itself
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
have u cleaned it yet?
完成的
添加一条评论
2个答案
最有帮助的答案
Hi @divyabonkey,
Sounds like your controller might need a bit of a cleaning, after carefully opening it.
Canned air and >99% isopropyl alcohol, along with some q-tips and a little time.
Hopefully it'll be alright with a good cleaning, or the switch inside could have decided to take a dirt nap.
这个答案有帮助吗?
得分 4
6条评论:
Where do i clean it? Should i open the controller and clean the whole r2 button?
完成的
Lil Prefires, Yes, you’ll have to open the controller up and clean the mechanism and button connected to R2
完成的
Alright thank you
完成的
@geirandersen should i clean the silicone wafer or the conductive film?
完成的
Lil Prefires, The best thing, is to carefully clean all the contacts, surfaces and points. Controllers tend to collect dirt and grime, because of the handling.
完成的
显示更多的1条评论
添加一条评论
does the springy part work still for the trigger work?
like when you press the trigger does it come back to normal position?
if yes the button switch inside on the actual PCB may need to be cleaned and or replaced. hopefully its not the latter. there are plenty of tear down guides for the DS4!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Divyakanth Kiri P 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 49
过去 30 天: 260
总计 19,847
