跳转到主内容
A game console released in North America by the Nintendo Company in 1985, called the Nintendo Entertainment System, model NES-001.
20 个问题 查看全部
Connecting to Modern TV
Hey! I was trying to connect my NES to my TV using the composite ports, but it won't work. Any suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hi @a_commodore_fan,
What is the make and model number of the TV?
完成的
添加一条评论
2个答案
已选择的解决方案
If the TV has composite ports and the NES has composite ports and you connect the RED to RED, WHITE to WHITE, YELLOW to YELLOW and set the TV input to the composite ports everything should work.
If it does not, then either the NES isn't transmitting, the cables are bad, or the TV isn't receiving.
To figure out which is a matter of substitution.
Connect to another TV. If it still does not work, then it probably isn't the TV.
Connect a different set of cables. If it still doesn't work, then it is probably your NES.
这个答案有帮助吗?
得分 1
1条评论:
Thanks, I will try it.
完成的
添加一条评论
I had the same issue with my LG tv. I bought this CONVERTER from amazon and it works great! still cant play duck hunt on modern tv's though =(
这个答案有帮助吗?
得分 1
1条评论:
I know. It's an unfortunate side affect from switching to LCD/LED. I might buy the converter.
完成的
添加一条评论
添加你的答案
[deleted] 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 29
过去 30 天: 78
总计 2,214
