跳转到主内容
2018年10月,谷歌发布的自有品牌手机Pixel的第三代产品。
106 个问题 查看全部
Pixel 3 dead, what will fix it?
My Pixel 3 is completely dead. No light, no vibration, no reaction to any button presses. If I put it on a wireless charger, the charger recognizes it, but then stops charging immediately. If I plug it into a USB-C power meter, it recognizes it's connected but doesn't charge. If I connect it to a computer, it doesn't list it as a newly connected USB device.
I noticed the battery was bulging, so I replaced that with the ifixit replacement. It still is dead.
So I'm wondering what might account for these failures? A bad replacement battery? A bad charging port? A bad motherboard? A cabling issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
All the above, plus possible residue on PCBs from the bulged battery.
这个答案有帮助吗?
得分 0
1条评论:
I think the most likely repair could be narrowed down from these symptoms.
Also, the battery bulged, it didn't leak, so why would there be residue?
完成的
添加一条评论
On my dead Pixel 3, connecting a USB cable to my Windows PC shows an unknown device:
QUSB_BULK_CID:xxxx_SN:xxxxxxxx
Many people are reporting this problem.
See:
https://forum.xda-developers.com/t/fix-p...
However, there's no solution at this time.
这个答案有帮助吗?
得分 0
1条评论:
Mine does not show up as a device when connected to a PC via a USB cable. I thought I read somewhere about there being solutions if that were the case. Perhaps I misread.
完成的
添加一条评论
添加你的答案
ross 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 33
总计 1,692
