跳转到主内容
Sony digital still camera model DSC-H50, February 2008, 3.0" tilting LCD, 9.1 MP CCD, Zoom 15x (31-465mm), f/2.7-4.5
Viewfinder not working, LCD is okay. How to repair?
My Sony DSC-H50's viewfinder does not illuminate when I switch from LCD to viewfinder mode. All other functions work, including the external LCD display. Does anyone know of a repair guide or video? My searches have turned up nothing.
EDIT: After posting this yesterday I did see the viewfinder flash (illuminate) briefly several times, but not in any reproducible way and not when I tried to switch to viewfinder mode. Seems most likely it is a loose connector.
EDIT2: I have attached the Sony repair manual (to the camera info page), but it doesn't really list steps, so I'm hesitant to dive in.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
6条评论
Have you tried disconnecting any unnecessary modules and testing ? I have encountered a similar issue on some canon cameras when the flash module was shorted
完成的
Thanks, HIF. This camera has no accessories/modules attached.
完成的
@hypercaff hey, I think you misunderstood me. I’m taking about the built in flash module which is present in this model.
完成的
You're right, I did misunderstand you. The flash module works fine. I haven't disconnected it because I haven't yet figured the right way to disassemble the camera.
完成的
@hypercaff this service manual should help.
Good luck !
https://www.manualslib.com/manual/125436...
完成的
显示更多的1条评论
添加一条评论
2个答案
已选择的解决方案
I got the camera apart (Thank you, @how_its_fixed!) and found that the ribbon cable between the main board and the viewfinder has several broken traces as shown below. For perversity's sake, pics were taken with the camera itself.
这个答案有帮助吗?
得分 1
3条评论:
It appears that flex was laying against something that got hot. That looks like it is burned. Replacing the cable should work, just make sure it is not touching what caused that.
完成的
I have the same problem today with the EVR of my Sony alpha 58 DSLR. Thankfully, I was able to see your post. This gives me a lead to how I can fix my camera. But then, how do you call this ribbon?
完成的
@josemarievillas This type cable is called a "flex cable", and, in this case, I assume it would be called the "viewfinder flex cable," or something similar.
完成的
添加一条评论
最有帮助的答案
Most cameras have a button to switch between LCD and viewfinder. You didn't say that you tried that or that it is suppose to be both on.
这个答案有帮助吗?
得分 1
1条评论:
Thanks, Bill. This camera only allows use of either the viewfinder or the LCD, and when I switch to viewfinder the viewfinder remains dark.
完成的
添加一条评论
添加你的答案
Hypercaff 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 34
总计 2,167
