跳转到主内容
发布于2018年9月21日,型号为A1921,A2101,A2102,A2104。支持GSM,CDMA / eSIM或 nano-SIM / 拥有64,256或512GB容量可选 / 有银色、金色、深空灰可选。(读作iPhone 10XS Max)
376 个问题 查看全部
Why does my screen go black randomly?
I recently replaced my broken screen on my iPhone XS Max with an IFixIt LCD screen. Since my phone screen was completely unresponsive to touch before replacing it, i wasn’t able to shut my phone down before repairing the screen. I just unplugged the battery connector and went on with the procedure. Now, randomly, my phone screen will go black while i’m using it but the phone is still on. All it takes to fix it temporarily is to turn the phone off and on. Now, is it because I unplugged the battery connector during the repair without shutting the phone down or is it a faulty screen? Please Help!!!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Unplugging the battery connector would not have caused any damage. In your description you say it is an LCD screen and these can be problematic and you should have purchased an OLED screen. If it is an OLED screen I would back the phone up and do an update or restore and see if the problem persists, if it does you will need to return the screen for a replacement. Before you do though I would make sure the top flex connector on the screen is seated properly and if the screen is losing image or backlight, you can do this by shinning a torch on the screen and see if you can make out an image.
这个答案有帮助吗?
得分 1
3条评论:
Hi @imicrosoldering
I thought OLED screens didn't have a backlight as the light comes from the pixels themselves, but I'm always willing to be corrected if I'm wrong ;-)
Cheers
完成的
@jayeff You are right Jeff. I was thinking if the ambient light sensor was playing up you should be able to see an image with a torch shined onto the screen.
完成的
@imicrosoldering
Learning all the time ;-)
Cheers
完成的
添加一条评论
WAIT...unplugged the battery connector during the repair without shutting the phone down?!?!?!?
congrats< now you need to replace the battery because you messed up there.
and also did you transfer the data of the original iPhone screen? that could be a problem 2
这个答案有帮助吗?
得分 0
1条评论:
didn’t have to be crabby abt it lol. I explained why i couldn’t power the phone down. i think i might contact ifixit for a different screen before i replace the battery
完成的
添加一条评论
添加你的答案
Nicholas Albensi 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 14
总计 202
