Identifieng motherboard component 220 | 6NF3E
I was fiddling with the MacBook's mainboard, and accidentally damage one of the components. The one that has a marking "220 | 6NF3E | d"
I assume it's a diode of some sort, but that is the limit of my knowledge. Now I wonder what the proper replacement would be.
Thank you.
3条评论
The large black three rectangular devices are tantalum capacitors you are referencing. I don't see any damage so I'm not sure thats your issue.
How about telling us a bit more here what happened, did you see spark or hear a pop sound or smell any smoke?
When you tried using the system what did it do and not do. The more you tell us the easier it is to help you.
由 Dan 完成的
The damaged one is not in the photo. it's simple mechanical damage. I was investigating the source of the short in the motherboard and accidentally ripped off the pad from the component while desoldering.
And yeah, the board still has a short somewhere. I just ran out of ideas on how to pinpoint it.
All small caps near the processor also shorted, so a assume it has something to do with VRM.
由 Lev 完成的
Okay after some tantalum rabbit hole exploration
220 - capacity (220μF)
d - 7343 case.
the rest - batch number of sorts
Those are probably custom components but reclaimed parts are somewhat available on Chinese marketplaces.
由 Lev 完成的
