跳转到主内容
加入维修社区 - 创建账户
Apple 在 2020 年十月更新了 iPad Air 平板电脑,其采用 A14 Boinic 处理器,10.9英寸屏幕,全新外观设计,以及内置在按键中的触控ID。
iPad Air 4 anti-repair measures
Are there any anti-repair boobytraps in this device? Touch-ID of course is probably coupled with logicboard I'm going to assume..
What about the screen for example though? Does swapping the screen with replica variant cause true-tone to disable?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi
This is a really good question HOWEVER…
Unfortunately people haven’t really tried looking for any anti repair traps so they are basically unknown but I can give you some information on what to expect and lookout for:-) (just from my experience from Apple products in general!)
When lifting up the screen be careful of the short screen cables as if you aren’t careful you can rip the connector off the board
Remember to disconnect the battery to prevent any damaged to components
Expect True Tone not to work (might work if the screen data is transferred over with the correct equipment)
Expect a “screen not genuine” message after the new screen is installed
And last but not least expect LOADS of adhesive as that’s what majority holds iPads together
If you have any more questions please ask;-)
Hopefully this helps
这个答案有帮助吗?
得分 2
3条评论:
Thank you for all this useful information. I've fixed many devices before and I'm aware of common obstacles. However I need some hard facts specifically about this device. Is the screen locked to the logicboard (for true tone)? Someone who has worked on this device probably knows the answer for sure.
完成的
@capacitor
Ok sounds good
Maybe try looking on YouTube for tutorials as they might mention the pairing issue:-)
完成的
Hello, I just replaced my logic board into another ipad and I can tell you about the anti-repair tactics that my ipad has. True tone still works even though everything in the ipad is replaced, and there are no “non-genuine” messages. What there is though has something to do with the apple pencil, as after i replaced the logic board the apple pencil is a bit squiggly when you write on it, it didn’t happen on my old ipad. Hope this helps!
完成的
添加一条评论
添加你的答案
Sam 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 38
总计 401
