跳转到主内容
Repair and disassembly information for Samsung's flagship S21 Ultra Android smartphone, released in January of 2021.
58 个问题 查看全部
logic board power button pin connector repair?
Hi guys recently droped my s21 Ultra phone in salt water... phone was constantly powering on and off untill the battery died.. The battery is toast and ended up expanding, so i opened it up to replace the battery but the salt had corroded the "power on button" connector on the logic board. (it totally fell off the board when i opened it up)
is it possible to repair/replace the pin connector on the logic board its self?
The phone says its charging with the new battery but i have no way to connect the power on button to the logic board so i also have no way to turn it on.
Below are some photos for refrence
in the bag is the connector that fell off and the area that is tarnished is where the connector was....
i know it doesnt look good but it should clean up alright with some isopropyl
No.1 is the connector in question.
Thoughts? and thank you for your time
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi
Yes you can replace that connector aslong as there are no ripped pads(as they would need fixing beforehand)
Unless you have good soldering experience I would have it seen to by a reputable independent repair shop as soldering connectors isn’t easy
However it’s not impossible if you know what you are doing
If you want to do it your self you would need a hot air rework station and some low melt solder
If you are going to do it and need any advice just ask anyone here:-)
Hopefully this helps
这个答案有帮助吗?
得分 2
2条评论:
Hi, thank you so much for your reply, i really appreciate it!
I think the pads have totally corroded off the board, it seems quite flat just by touch and looking by eye, i will have to take it to a professional as micro work is beyond my skill set. hopefully it is still repairable
完成的
@nicholas.t.ellison
Good luck:-)
完成的
添加一条评论
添加你的答案
nicholas.t.ellison 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 19
总计 173
