跳转到主内容
苹果第四代智能手表,含可选的蜂窝连接支持,2018年9月21日发布。
125 个问题 查看全部
adhesive on the edge where the display cables are running
Hello,
during the opening of my Apple Watch 4 serie, I broke the adhesive on the edge where the display cables are running, cutting the two connections towards the two corners on the bottom of the case.
Question: which is the technical function of this adhesive? is it strictly necessary? Is it available as spare part?
Thank you
Regards,
Giancarlo
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi
The screen connector adhesive you are on about that really only holds down some black tape to cover the connectors so I wouldn’t worry about that:-)
Hopefully this answers your question
If you need any help please ask
这个答案有帮助吗?
得分 1
8条评论:
Hi,
thank you for the answer. I know the force touch. My question is regarding the adhesive very thin that is behind the display that keeps the three flat cables of the display glued together.
完成的
@gianko
That adhesive doesn’t serve much of a purpose other than covering up the connectors:-)
完成的
@hellomacos good news, thank you very much! have a nice day! :-)
完成的
@gianko
Have a nice day too!
完成的
@hellomacos - Please becareful as some of your comments of late don't solve the underlying problem/s or deal with the ramification of incomplete information.
I would stick with areas I know intimately from experience, maybe even looking through older answers to see if the question was asked before and then pointing to that question and answer. I always try to supply data to back up what I've offered that helps people as well.
完成的
显示更多的3条评论
添加一条评论
@gianko - The black copper tape is an EMI shield and you do need to be careful as you don't want it shorting out things. How about posting a picture or two so we can see things 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Giancarlo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 12
总计 91
