跳转到主内容
Xiaomi Redmi Note 5 is a budget Android smartphone, from 2018 that shipped with Android 8.
Smartphone bent by falling. Need to get access to its data
Hi,
had my redmi note 5 in my backpocket when falling. Thus it is bent between battery and mainboard. Display, clearly, is broken and is not showing anything.
As there it relevant data on it (pictures of pregnancy and birth of my daughter) I really like to get access to the internal memory to read out the pictures.
To get access, I tried connecting it via USB to my computer (windows 10). Device Manger showed it as QUSB_BULK device. Drivers could not be found.
When for test, I checked another Windows 10 computer, QUSB_BULK driver where found it windows was able to install them at least. Now, it shows up as "Qualcom HS-USB QDLoader 9008 (COM3)".
Can anyone give hints how to continue and how I can get access to the memory?
Or if it is not possible via USB and which alternatives I can check?
Thank you in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
you could connect it to a monitor using 1 of these https://www.aliexpress.com/item/10050034.... using a usb mouse and keyboard should let you use the screen if theres a lock on it then you could connect to the pc to backup the data
这个答案有帮助吗?
得分 1
添加一条评论
Where you able to get your data or get your phone repaired without losing data? I'm having the exact same issue but for me, my phone did not fall or anything. it just randomly stopped working and showing QUSB_BULK on my PC
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dominik 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 6
总计 827
