跳转到主内容
The Razer Blade Stealth is a gaming laptop with a 13.3 inch wide screen. The laptop features 16 GB of RAM and an Intel Core i7 CPU. It comes in Space Grey and Mercury White.
8 个问题 查看全部
Can I case-swap black and white Razer Blade Stealth 13?
Got a 2020 black RZ09-0327 with German keyboard, would like to swap internals with a 2019 white RZ09-03100 with US keyboard. Because of the color and keyboard.
They look same on pix, same dimensions, same ports, screen has same size and res.
The 2020 has a GPU, 2019 only CPU.
Thank you!
R
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
no the detentions r not the same and different screen hinge in different places
这个答案有帮助吗?
得分 0
3条评论:
thank you for answering. basically i just need to swap the motherboard. not possible? have you tried it?
完成的
Ya u met be able to get away with the motherboard it's all amount of space and hardware compatibility so if theres space and u have compatible parts yes and that brings me make to gutting laptops to stack cpu and ram for my school lmfao
完成的
thank you, will report if i do it
完成的
添加一条评论
添加你的答案
vizzwizz 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 12
总计 167
