跳转到主内容
Released in October 2012, identified by model number CQ58-bf9WM, 1.0GHz AMD Dual-Core Processor C-60.
6 个问题 查看全部
Laptop not turning on but charging led light blinks white
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
If the motherboard is burnt on the charging side what can be done
完成的
添加一条评论
1个答案
最有帮助的答案
Hi,
Try a power refresh and check if that resolves the problem.
  • Disconnect the charger from the laptop and then remove the battery from the laptop. Here's the ifixit HP Compaq CQ58-bf9WM Battery Replacement guide that shows how to do this.
  • Press and hold the laptop's Power On button for a full 15 seconds and then release it.
  • Reinsert the battery into the laptop.
  • Reconnect the charger and try turning on the laptop.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Thapelo Molale 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 161
