跳转到主内容
Repair documentation for the Fitbit Versa 2 smartwatch. Released in September 2019.
My Fitbit won’t charge
My Fitbit is dead and it won’t take a charge what can I do
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
When i purchase my watch after it never charged what should i do
完成的
添加一条评论
3个答案
最有帮助的答案
Hey, it depends on whether its not charging or if its not taking a charge.
If it is showing that its charging but after unplugging it you see that its not taking charge its very likely to be a battery issue. To solve that you would need to replace the battery(Available for many of the fitbits) but this requires some technical abilities.
If its not charging at all there is a vast amount of possibilities of what could be wrong but you could attempt to clean out any debris from the charging connector on both the watch as well as the charger.
这个答案有帮助吗?
得分 1
添加一条评论
I Have a Versa 2 and was facing the same issue but Thankfully I have got a solution which was fixed it.
here are few of them that worked for me and a several other on a detailed post.
这个答案有帮助吗?
得分 1
添加一条评论
You have to sync it to the fit bit app..once u do that it will update the time etc
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Susan Scheidt 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 57
总计 5,646
