跳转到主内容
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
Thunderbolt not Working Firmware Problem?
Hi ive just bought a Lacie 4TB Thunderbolt drive
Trouble is its not being recognized on my 2012 15" Unibody as the port seems dead
So for the last 3 days ive been trying to fix it with out success
Ive read that the port wont work with Micro port firmware version 1.2.1 which mine is is there a way i can get to install the right firmware to get this to work
I have tried this without success
Thunderbolt Port not working correctly!!
Has anyone had experience with this and was able to fix it
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Under About This Mac - Hardware Report your Thunderbolt port info should show: Firmware Version: 25.1
Thats what my 2012 15" MacBook Pro has.
Typically the OS installer will update the firmware when needed. But the order of upgrading your OS could be a factor as Apple sometimes messes up dropping the update in newer versions of installers. So I would first look at what it your current OS-X/macOS to see where you are.
So what are you running now?
这个答案有帮助吗?
得分 0
4条评论:
Thanks for the reply
It is on Firmware Version: 25.1 and the Micro port firmware version 1.2.1
Its on Mojave
But the ports dead showing no life at all
Thxs
完成的
MyTB Ports Micro Firmware is Version: 2.1.3
I think you've got a messed up logic board as the micro code gets into the display aspect.
完成的
Thanks Dan
Is there anything that can be done to fix it?
Thanks
完成的
@junkmanuk - There are people who repair logic boards, or you could see if you can find a replacement logic board as I'm sure the cost will be about the same and you'll likely be without your system for quite awhile.
As it turns out iFixit has the part MacBook Pro 15" Unibody (Mid 2012) 2.3 GHz Logic Board in stock and here's the guide to put it in MacBook Pro 15" Unibody Mid 2012 Logic Board Replacement.
But before you make the jump do check locally if you can find someone who can fix your logic board.
完成的
添加一条评论
添加你的答案
Junk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 553
