跳转到主内容
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
383 个问题 查看全部
Cpu fan running on full speed while starting up
I cleaned my old mac from dust, collected everything and the CPU FAN started working at full speed when the computer started. In the "Macs Fan Control" it showed zero fan speed, although everything was connected and checked
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Clearly you CPU fan has failed! iMac Intel 27" (Late 2009-Mid 2011) CPU Fan
iMac Intel 27" (Late 2009-Mid 2011) CPU Fan图片
产品
$24.99
这个答案有帮助吗?
得分 3
27条评论:
Only one solution to change it?
完成的
@?????? - The motor and/or the tach has failed.
You could take it out and check motors windings resistance and if applying some air flow to it the tach reports voltage. But in the end its' time for a new part.
完成的
forgot to say, i have 2 ssds, one installed at optical drive
完成的
@?????? - and that changes things?
完成的
@danj - He Might be saying that because it could affect the fans because of the thermal sensor for the SSDs
完成的
显示更多的22条评论
添加一条评论
添加你的答案
?????? 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 194
