跳转到主内容
Manual turntable with built-in phono preamp and premium A/D conversion and USB output.
4 个问题 查看全部
Which pliers to use to change cartridge on a Pro-Ject Debut / X1 TT?
Hello fellow iFixers!
I want to replace my TT cartridge with an Ortofon 2m Black cart, and I read someplace someone advised using pliers to pull the headshell's wires off the cartridge's pins, so not to damage the wires. Can you recommend a specific set of pliers from iFixit? Should I get other tools to assist me with the replacement?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The wires can be removed from the cartridge by GENTLY pushing them apart from the back of the cartridge using the blade of a tiny screwdriver such as you’d use to install a cartridge. Those original wire leads are extremely delicate, so be careful. I wouldn’t use pliers at all to install the new cartridge, I’d use tweezers. Check out the Micro-Mark tool catalogue online. Now, if you do break those tiny original wire leads, you can replace them with another fragile Pro-Ject tonearm cable or go aftermarket, such as with the Cardas tonearm cable you see online. Do NOT attempt to repair a broken tonearm cable!! I should mention that later-model Pro-Ject tonearm cable isn’t quite so fragile as the original, and some would object to the price of the Cardas option, which is comparatively quite high. (There are idiots who substitute wire from computer mice!) When I had to rewire my own tonearm due to a broken original cable, I chose aftermarket (Cardas) because Pro-Ject hadn’t yet introduced their new sturdier cable. But today at least you have a choice, with two valid options.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tal A 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 130
