跳转到主内容
Repair and disassembly information for Samsung's flagship S21 Ultra Android smartphone, released in January of 2021.
58 个问题 查看全部
Rear back camera lens/glass cracked, any issues using 3rd party lenses
I'd like to avoid taking the entire back panel off and it seems the old camera glass can be pryed off and the new one installed. Wondering if anyone has done this/ how the 3rd party glass compares to Samsung OEM back camera lens glass?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Fed,
Personally, I've replaced lenses on my Pixel 2 and a couple of iPhones and never had a problem with aftermarket glass.
There is something to be said for removing the back cover to do the replacement. For me, the main advantage is that you can do a better job of cleaning out any broken glass particles from the camera lens(es) with the cover off, plus you can push the old lens out from the inside and avoid scratching your housing while prying out the broken glass.
There's a decent video demonstrating the whole process over at iphonewired.com: Samsung Galaxy S21 Ultra Camera Glass Restoration - iPhone Wired, but all in all it's a fairly easy process whether you decide to remove the back or not. If the glass just has like a single crack I'd go for not removing the back, but if it's shattered with glass shards you might want to consider taking it off.
Best of luck!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Fed 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 21
总计 203
