跳转到主内容
Repair and disassembly information for Samsung's S22 Ultra smartphone, released in February 2022.
63 个问题 查看全部
Why is my Samsung galaxy s22 ultra volume button not working!?
Hi, My Samsung galaxy s22 ultra volume physical down button not working after water damage!
Volume up button and power button works normal!
And phone works normal too!
After tearing down found no corrosions on any connections or on board except some white colour of corrosion on the back upper left corner on housing but not on any parts or circuit board other then that everything looks in very good condition !
also Zoomed in with my other s22 ultra micro zoom Camera and found no signsof corrosionon any parts!
I have Replaced volume and power button flex cable with brand new flex!
And also i have Submerged motherboard in isopropyl alcohol for at least 2 hrs.
Tauch cleaned with isopropyl where possible with eurbuds and on every connection!
All air dried.
Still can't seem to understand why the volume physical down button don't seem to work?
Any suggestions pls!
I have not submerged the cables yet?
As I don't see any link between volume button and display cables!
Could it be the motherboard! ?
Can u help me with ASAP pls!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Maybe it’s the connected on the board something similar happen to my 3ds it probably the lock that holds down the ribbon cable
这个答案有帮助吗?
得分 0
添加一条评论
I think you're on the right track with the Motherboard. More specifically, the Cirrus Logic CS35L40 Audio Amplifier IC on the Motherboard. The moisture probably short circuited a channel in this IC. Yup, time for some microsoldering.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mo abdul 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 34
总计 1,415
