跳转到主内容
加入维修社区 - 创建账户
3rd Generation high performance tablet computer released by Apple in October 2018. Models A1876, A2014, and A1895.
upper Volume Button Stuck
In the process of replacing a screen and testing it the volume up button is now stuck. i have removed 2 screws which held a cover in place. Is the pcb that the buttons are attached to glued to the chassis? Anyone know?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
From looking at this
https://www.etechparts.com/power-and-vol...
it looks like they have some kind of adhesive on the ribbons
这个答案有帮助吗?
得分 1
4条评论:
There were three screws which i have reoved but if they are glued in place thats just overkill. Problem is i cant get the ipad to power off because of the stuck volume button. I dont know if using a heat gun to loosen the cable will damage the power flex cable.
Thanks for your replay.
完成的
as long as you dont bake the ribbon id think youd be ok. just do quick passes on it while gently tugging on it.
完成的
thanks, thats what i did and have now been able to fix the sticky volume key issue
完成的
@Ask ArgyllTechfix alcohol is almosst always a cure all lol. try taking some and soaking hte button in it while its disconnected and just cylcing the !&&* out of the button and rinse it out with more alcohol. if that doesnt make it click again then the little membrane in the switch might actually be done for and need to be replaced
完成的
添加一条评论
添加你的答案
Ask ArgyllTechfix 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 265
