跳转到主内容
Oculus Quest 2 是 2019 年 5 月 21 日发布的 Oculus Quest 的继任者。Quest 2 是一款经过改进的型号,具有更好的处理器和重新设计的触摸控制器。
165 个问题 查看全部
Why wont my Quest 2 pair with my phone
Oculus quest 2 will not pair with my phone and will not track i tried to force reset but that made the quest soft lock and i cannot get of the screen showing me to remove the controller sticks and will only has the 3 dots
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
If you completley power off the headset, and then hold the power button and the volume down At the same time you can factory reset it. if this does not help please reply to this comment
这个答案有帮助吗?
得分 0
2条评论:
Have issue where device was Factory reset, starts up, goes to "pairing" on phone said iy cannot pair because update is needed. Can't update because I can't get past this screen to connect to wifi.. any tips?
完成的
When the headset is factory reset, do not try to pair it untill it prompts you, it will update itself when starting normally
完成的
添加一条评论
添加你的答案
Corbin Cassidy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 8
总计 384
