跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for all household mechanical fans including ceiling, box, tower, and stand fans.
My motor won't work
How can I tell if my motor is burned out
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Motor for what? Need more info such as what the motor is powering and such?
完成的
添加一条评论
1个答案
I'm guessing you're asking about a ceiling fan. Could be wrong. But to check it you need a multimeter. Do a continuity check from N to ground, and from each winding. Then to a continuity check across each speed to N. If I remember correctly the slower the speed, the higher the resistance. If it shows continuity to ground then it's toast. If it show OL from any speed to N, then it's toast. If each speed reads the same amount of resistance, then the windings have shorted together. Also check the capacitor. Now, in the event you aren't talking about a ceiling fan... this should still work. Unless we are talking about ECM motors. Those are more complicated but much less common.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joseph Sanchez 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 111
