跳转到主内容
加入维修社区 - 创建账户
A business-class notebook with a 13.3" touchscreen display.
Battery won't charge
I wrongly connected wires of PC charger , it gave a message and shutdown (I don't remember )
Ever since then it has not been able to charge laptop battery
But when I put the same battery on another PC it charged
Any possible fix to this pc
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
6条评论:
Does this happen with every battery you put in or just this one?
完成的
Every battery
完成的
@Albert Maliro jnr
What is the model number of the motherboard as printed on the motherboard itself?
Just verifying whether you can turn on the laptop OK but it just won't charge or whether it won't turn on either with a good charger connected?
完成的
How do I check the model number?
Yes I can turn on the laptop properly
完成的
@Albert Maliro jnr
You will have to open the laptop and find it printed on the motherboard.
Here's a guide - HP EliteBook 840 G1.
Just asking as it seems that there are different 840 G1 models that have slightly different motherboards and I suspect that when you reversed the power you damaged a component on the motherboard and the correct schematics will have to be found for it to know where to look and what it may be or is (if it is burnt out and can't be recognized).
When it is open you can also look for any obvious damage i.e. burnt out components
完成的
显示更多的1条评论
添加一条评论
1个答案
Well If the battery is fine than check the charger because it can also mean that the charger not working and you need new charger for Or you can also check for the driver in your system if an outdated driver you found which in related to power issue that you should update or fix that driver by using a good driver updated software
这个答案有帮助吗?
得分 0
1条评论:
The charger and the driver are all ok
完成的
添加一条评论
添加你的答案
Albert Maliro jnr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 262
