跳转到主内容
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
426 个问题 查看全部
Display LCD chips overheating
After replacing a cracked digitiser screen the chips at the bottom of the LCD display are getting very hot during use, I estimate 40 - 50 oC and eventually the digitiser loses sensitivity. It cools down when no apps are being used and is then ok. It takes about 30 minutes of game play to get hot. Any suggestions welcome.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It doesn’t sound like a problem to me, seems to be expected behavior.
这个答案有帮助吗?
得分 0
3条评论:
Thanks, but I didn't expect it as it didn't happen before I changed the digitiser screen. Is it normal for the screen to lose all touch sensitivity after 30 minutes?
Regards
Bob
完成的
@bob_pluck losing sensitivity shouldn’t happen, but your description is too vague to tell for sure. Which chip is overheating?
完成的
The row at the bottom rear of the LCD display. Highest temperature at the cable end of the strip.
I have tried to attach an image but not sure if it has worked.
完成的
添加一条评论
添加你的答案
Bob Pluck 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 39
