跳转到主内容
加入维修社区 - 创建账户
The Dyson V8 Animal is a cordless vacuum equipped with powerful suction that can last up 40 minutes on one charge.
Dyson V15 doesn't hold charge overnight (tried two batteries)
So I charge the dyson and it works fine whilst im using it now if I put it down overnight (not in the cradle) it is dead come morning. If I disconnect the battery and put it back the next day its fine. So its like there is a short or something? Any ideas. I have got a free new extra battery to the same effect from Dyson
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi
iv seen this a couple times online and me personally would see if Dyson will replace your unit as Dyson handheld vacuums are not made to be taken apart at all(on the motor housing side that is)
if you really wanted to you could get it but would cause severe damage to the device in the process!
if its a v15 its fairly new so just in case I would let Dyson deal with it as if you take it apart they might void your warranty
sorry there isn't much of a solution
but I hope all goes well for you
这个答案有帮助吗?
得分 1
1条评论:
Same issue with my v15. Did you find a solution
完成的
添加一条评论
添加你的答案
Ashley Towers 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 490
