跳转到主内容
Seventh generation of iPad, released September 25, 2019, available in 32 or 128 GB models. Model Number A2197.
20 个问题 查看全部
Damaged prongs for home button. Will the iPad work?
The connector where the home button ribbon attaches is broken. Will the iPad work with no home button attached there and broken prongs? I have the assistive touch so I can use that. Just wondering if it will function other than that.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi,
An iPad (or iPhone) is able to start without having a home button connected, absolutely.
Note: I have seen reports (though never experienced it myself) that when it boots without the home button, the process can take quite a bit longer than normal.
这个答案有帮助吗?
得分 2
2条评论:
Thank you unfortunately I messed with the display too much and tore the ribbon cable on it. So I learned some things but this iPad is done.
完成的
@Debbie Santora
Are you sure it’s done?
There’s 1000 of ways to fix things:-)
完成的
添加一条评论
添加你的答案
Debbie Santora 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 723
