跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for top and front loading Whirlpool brand washers.
Spin cycle sometimes won't start
Whirlpool top load washer. Gets to spin cycle and doesn't start but I can hear motor. If I turn off wash cycle and turn back on the spin cycle kicks in and completes.
I thought clutch was issue, replaced and still happening.
Any thoughts? Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi,
What is the model number of the washer?
完成的
@jayeff Model # Lxr7244jq3
完成的
添加一条评论
1个答案
已选择的解决方案
@M. Kornhoff
Sorry for the delay.
I was trying to locate the tech sheet for the model (Whirlpool 4313896 aka LIT4313896) to hopefully see the wiring diagram for the washer to check if the cycle timer was the problem by knowing what timer contacts are used for the spin cycle. It may be a worn cam or a worn or dirty contact in the timer.
Unfortunately timers are not reparable, they have to be replaced. (part #WP8572976 I think - maybe confirm if number printed on timer)
Given the cost of a timer, (search online for the part number), you could try liberally spraying a specialist electrical/electronic contact cleaner (example only, there are others) into the timer to see if this clears the problem. Disconnect the power before doing this and allow sufficient time to dry before reconnecting the power to the machine.
Do not open the timer as you will have cams and contacts everywhere - usually there are about 12 cams and 20+ contacts in a timer. Hopefully there may be some holes in the casing that you can use. Also do not use standard WD40 as it leaves residues.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
M. Kornhoff 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 1,288
