跳转到主内容
各類時鐘的維修指南和支援信息。
How to keep battery powered clock from slowing down
my battery clock runs slow even with new batteries installed. is there a fix for this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
This is a fix that is more complex than my clock; it does give me an idea for upgrading to a better time piece. Thank you.
完成的
添加一条评论
2个答案
已选择的解决方案
While altering the crystals timing can improve your clocks time keeping, it may not offer enough as the battery runs down.
Another way of having a clock that syncs up with WWVB which is a radio signal many clocks use to hold their time. Another source is the Internet time server which you can access over the internet. Some clocks today can leverage it via WiFi or even a hardwired Ethernet connection, as an example my weather station does this.
Sadly, these options will likely require a new clock to leverage.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
@ortheo There are ways to calibrate a quartz watch movement, but it depends on what exact movement is used in that watch.
Most watches lose or gain seconds (sometimes several a day), even high end Rolex mechanical and Patek Philipes! Mechanical watches usually requires a watchmaker with highly sensitive equipment to get just right. And watches are also subject to interference from static, like magnetism, etc.
If you can, either by finding your manual or opening the back cover, find the exact movement part number and Google fex (Seagull 2551 quartz movement calibration)
(That movement is the current most used Chinese movement.)
I have a SEIKO Solar which I’ve had for a year or so, and it loses about 1-2 seconds bimonthly (which is how often I have to adjust it because of the calendar).
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ted Rockwell 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 14
过去 30 天: 129
总计 4,074
