跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
iPhone 6 LCD (and battery?) don’t work
Bare with me haha.
So I am getting into fixing iPhones, and I started practicing on an old iPhone 6. I’m pretty sure the battery has been replaced bc it doesn’t have an Apple logo. Anyways, when I was practicing reconnecting the display, it showed glitched white vertical lines. I simple reseated the lcd cables and that fixed it. But the next time I reconnected the screen, the same white bars showed up, the only difference was no matter how many times I replugged the cables, it was the same glitches every time. I think the screen cables have just worn out as this phone looks to have been opened a lot. One of the times I reconnect the lcd it was completely black, and I plugged it in. When I did so it buzzed when connected to power (remember that) but still was glitched when I reseated the cables. I did some research and found that you are supposed to unplug the battery when replacing the screen, so I did. I installed the lcd cables and then reconnected the battery, but now there is nothing. The mother board definitely feels warm as usual, but the lcd is plain black with no backlight and when I plug in the phone it does not vibrate at all. Please let me know if any of you have a solution.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You likely fried one or more components on the logic board while you were working on it with power still running through it. NEVER work on a powered system. Consider this a learning experience.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Henry Kelleher 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 19
