跳转到主内容
加入维修社区 - 创建账户
Lenovo ThinkPad L460 是联想于 2016 年 1 月发布的一款 14 英寸商用笔记本电脑。它拥有坚固的机身、哑光黑色设计,键盘中央配有红色的 TrackPoint。其重量通常约为 1.9 kg(4.2 磅),搭载英特尔第六代酷睿处理器,并具备多种可靠性特性。它非常适合商用或教育用途。
Problem with screen or motherboad?
My lenovo T460 has no 3.3V and no other voltages on screen controller board (CON) except the 20V on the connector and in a big coil. Also no backlight and no picture. Is it possible to have fry anything in main motherboad ? (My hdmi output working normally with my external monitor).
Initially I changed the screen cable, because my screen was changing colors and making vertical shades with freezing picture, especially when the lid was moving.
Initially the problem seems to had be solved ,but after 5 min the problems return, so I opened the screen and begun probing on the CON for voltages and any defect cups and at that time the backlight and the picture was on, with the defects showing..
Now it's only a black screen.(with working hdmi output to TV)
The question is how do I know that I haven't done anything wrong with the motherboard, while I was probing the screen con board ? The 3.3V and other voltages are coming from the motherboard though the screen cable or from the lcd controller board?
Where could I have to start searching ?
I Appreciate your time
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Mine has no display but shows charging light and power light
由完成的 分享
添加一条评论
1个答案
已选择的解决方案
Hi @metachaos
Couldn't find a schematic for a T460 but found one for a T460s (Compal NM-A581 motherboard) which shows that the backlight power is supplied via fuse F6 on the motherboard and goes to pins 27 & 28 on the LCD connector.
If the fuse is blown it is a 3A_32V_ERBRD3R00X.
If there is no power on either side of the fuse, the power comes from Q1 (TPCF8002_2-3U1A)
If there is power on the pins then then backlight is turned on and off in the screen by a backlight enable signal sent on pin 18.
Here's the schematics that may help you further, (scroll down to the download link). Go to p.38 to see the pinout for the LCD cable connector.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Lord Chaos 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 35
总计 1,169
