跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
Headphone jack only plays out of one side.
I replaced the Lightning Connector Assembly in a second iPhone 5c. The first one went fine and works perfectly. On the second phone the headphone jack only plays through the right side of the headphones. I tried connecting multiple headphones that I know work on both sides with the same result. Is it possible that the headphone jack in the Lightning Connector Assembly is defective or could I have done something incorrectly in the installation of the replacement part?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi
I would try cleaning the headphone jack as iv used many different headphones and this happens quite a lot with stuff that hasn’t been cleaned
Make sure there are not corrosion on any other the pins inside the headphone jack or the aux jack(headphone cable end)
One of the 3 bits of the headphone jack may be corroded as 1 does left,1does right,1does the mic,if one of these is corroded you might find it doesn’t work properly ,I have put a photo for a example
Try isopropyl alcohol for cleaning,that’s what I find works a treat!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Vincent DelGuidice 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 4
总计 40
